Creo 4 Tangent Leader not available for Feature Control Frame
SOLVED
Highlighted
Regular Member
Struggling with GD&T changes in Creo 4 since using Pro/Engineer for the last 22 years. In a drawing, I'm trying to attach a GD&T Feature Control Frame with a tangent leader and it appears a "tangent leader" attachment is not available. I've tried this in the part and drawing. The best I can do is a leader pointing to the edge/plane. REF: ASME Y14.5-2009, 3.5(c) - "A feature control frame is related to a considered feature by ... attaching a side, corner, or an end of the frame to an extension line from the feature, provided it is a plane surface". See attached for an example.
1 ACCEPTED SOLUTION
Highlighted
Re: Creo 4 Tangent Leader not available for Feature Control Frame
@akelly
Use SHIFT,
Select GTOL, Shift + select text and move
5 REPLIES 5
Highlighted
You have to use a leader.  While the end result looks correct, the workflow is not intuitive.
Here is a video tech support sent me showing how to do this:
Highlighted
Thanks a bunch.  I never would have figured that out without the video.  If it was covered in the CP2 to CP4 Precision LMS course, they touched on it so lightly that it didn't register.
Highlighted
Still having trouble. See attached.  I'm using draft GD&T.  I want the feature control frame to the RIGHT of the tangent leader, but it keeps snapping to the LEFT.  Not a good placement for the view and dimensions
Highlighted
@akelly
Use SHIFT,
Thanks. Good Lawd CP4 is complicated.  Requires un-learning 20 years of good habits.
