I want to animate an assembly and save as an mpeg. This is pretty basic, yet I dont know how to do it and cannot find any tutorials. I want to take an assembly and just rotate it to show different views, how can this be done. I'm thinking you create an axis and rotate it around or just create several views, place this in order and then animate, if this is the case it seems like it would be easy. Need to know how to do this or access to a tutorial.
Yes, you simply define views to use in the animation dialog (timeline). You have 2 options for the transition between orientations. Be aware that perspective views have a few quirks.
I thought we still had a flythrough option, but I don't know how this works in Creo.
