Creo Drawing Note
Highlighted
Regular Member
Creo Drawing Note
I have a Problem!
I want to place a Symbol or Text note with frame, so that Note cover lines from the views. you have a solution?
In other words, Symbol or Text Frame should be in front of View and not transparent.
Highlighted
Re: Creo Drawing Note
unfortunatelly requested functionality is not implemented in Creo.
MH
Martin Hanák
Highlighted
You can't make a text box do that, but I think you can hide portions of the lines so they don't cross the box.
I would usually just move the box.
