Creo Exporting Help
taldrich
1-Newbie
Creo Exporting Help
When I export my model as a step file (also tried IGES & Parasolid) the surfaces used to create various part shows up when importing into Solidworks.  My Export STEP settings has surfaces unchecked (see picture below).  If I open the step file back up in Creo it opens correctly but my customer uses Solidworks and sees all the surfaces after importing.  How do I make sure these surfaces don't show up when exporting from Creo & importing into solidworks?
1 ACCEPTED SOLUTION
habdul
6-Contributor
(To:taldrich)
Todd,
What if you uncheck "shells" in the export dialog? I tried that and the surface didn't show.
Hatim
5 REPLIES 5
habdul
6-Contributor
(To:taldrich)
I noticed that the imported surface appears as a separate feature in SolidWorks feature tree. It's possible to simply suppress it.
habdul
6-Contributor
(To:taldrich)
Todd,
Hatim
Hitim,
Thank you for your response.  By unchecking shells this seemed to work.
test this procedure (in the past it worked for IGES format):
  • add following option into config.pro file
    intf_out_blanked_entities no
  • start Creo and export your model
For options description see http://www.proesite.com/cgi-bin/find_option.cgi?srch=INTF_OUT_BLANKED_ENTITIES&ver=wildfire
MH
Martin Hanák
MH,
I tried this but I beilieve it had more to do with skeleton surfaces then layers.  After unchecking shells it seemed to pull into Solidworks just fine.
