Is there any way to export an animation in Creo Illustrate 2.0 so that the resultant file does not display as a very wide and narrow .wmv? It looks like the worst wide screened movie ever! I'm losing call-outs and other bits of information as a result. Any help would be appreciated. BW
if you upload some example using How to attach file when you Reply to a discussion. procedure, I can test it on my PC.
MH
