Each time I try to export a file as an stl, I get the warning stating that the part is in negative space. No matter where
I position it, the warning persists. I Are there some settings I can adjust to avoid this. Is there an icon that dsiplays the parts XYZ coordinates?
Would you let me use a sample file with that problem to do it some tests? I had no problems yet exporting from PRO/E to .stl to use it in 3D printing, but that negative values alerts... I see it in .dwg to .stl
Can you borrow me some of your files in a post?
Best regards
Faustino Garcia
Hi Faustino,
I have the same problem. Files enclosed.
Kindest Regards
Is it a problem? If so, get a copy of MeshLab from http://meshlab.sourceforge.net/ to do any changes needed, but it may not be a problem at all:
From http://www.stereolithography.com/exporting-stl-files.php
"Some CAD systems will generate error messages during STL conversion saying that some part geometry is outside of the positive X, Y, Z quadrant or is in negative space. These messages can be ignored, as the STL file will be located in the rapid prototyping machine’s build space and oriented for optimal surface finish and build speed by the system software."
