Can anyone point me to documentation on how the mapkeys changed to get a better understanding?
More details:
Thanks! Lawrence
similar discussion here:
https://community.ptc.com/t5/System-Administration/Creo-4-mapkeys/td-p/560196
The best thing to do is to insert text using the property dialog box or using insert from file.
as far as I know ... no documentation concerning mapkey coding is available. You can apply "method of trial and error" :). You can also publish your mapkey here and hope that someone will help you.
