Creo4 cannot select image?
LawrenceS
18-Opal
It seems that images can only be selected if you are in the image editor, and the ALT button doesn't work.
Has anyone found a way to select images when not in that editor, or are we stuck with this?
"When you reward an activity, you get more of it!"
As I know there is no other way to select the images. you need to be in the Image tab to select the image.
I found that it also helps to add the command to the right click menu to edit image.  Thanks for your help.
