Creo4 cannot select image?
SOLVED
Level 12
It seems that images can only be selected if you are in the image editor, and the ALT button doesn't work.
Has anyone found a way to select images when not in that editor, or are we stuck with this?
1 ACCEPTED SOLUTION
Re: Creo4 cannot select image?
As I know there is no other way to select the images. you need to be in the Image tab to select the image.
2 REPLIES 2
Highlighted
I found that it also helps to add the command to the right click menu to edit image.  Thanks for your help.
Tags (1)
