Cross-hatched cross section - WF4
I'm modelling an assembly which includes a gauze panel, and I've come to create the first cross section.
For the gauze part I want a cross-hatched appearance with lines at 45° and 135°. However, when I change the angle of one line set, the other set changes with it - I can have two sets of lines, but only at the same angle as each other!
Is this a bug with WF4 M220? Is it broken functionality for all versions? How else can I achieve this?
