Curve equation: IF statement?
JonathanHodgson
11-Garnet
Hopefully a quick one:
Can you use IF statements in the equation of a curve (WF4.0)?
If so, could someone please point me to the correct syntax?
Thanks!
Jonathan
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender immediately and delete this e-mail from your system. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of Ricardo (save for reports and other documentation formally approved and signed for release to the intended recipient). Only Directors are authorised to enter into legally binding obligations on behalf of Ricardo. Ricardo may monitor outgoing and incoming e-mails and other telecommunications systems.
By replying to this e-mail you give consent to such monitoring. The recipient should check e-mail and any attachments for the presence of viruses. Ricardo accepts no liability for any damage caused by any virus transmitted by this e-mail. "Ricardo" means Ricardo plc and its subsidiary companies.
Ricardo plc is a public limited company registered in England with registered number 00222915.
The registered office of Ricardo plc is Shoreham Technical Centre, Shoreham-by Sea, West Sussex, BN43 5FG.
If you edit the relations of the curve feature, the equations show up as releations. You can add any IF statements in that interface. You can also type them in when you create the feature. Ths syntax is the same as in any other relation.
Peter Stockhausen
Infotech Aerospace Services
