Customize All Modes From Creo Parametric Options Menu
breed
For users who customize different modes differently it would be nice to have the following features:
  1. Add dropdown in the Creo Parametric Options under the "Customize Ribbon" Category to allow you to change what mode  you are editing.
  2. Allow the ability to save tabs to the left column so you can place them into other modes. (Possibly add a "customized tabs" from the dropdown similar to the current "mapkeys" option in that dropdown)
  3. In the Customize Ribbon interface there is an empty spot next to the modify button it would be nice to have a button there that toggles through the different sizes found in the modify drop down or several small buttons for different sizes of icons would be nice too.
  4. Add additional option in the Creo Parametric Options dialog to configure .dtl files. (Keep everything centralized for intuitive easy access)
Hans-Dieter
(To:breed)
I would also like to see a button "Add to all modes" - if you want to add a button to load a special config or for fast exit etc. that should be available everywhere.
