DATUM on several views
Garnet
using CREO 4, I have defined a Datum plane (in 3D model using Annotate Feature - C in this pic) related to a dimension.
In the drawing I can see this Datum Ref in the view in which I see the dimension.
But, is it possible, with some tricks, to visualize the same datum plane in other views ?
I know that it's possible if the Datum is related to a surface, but I need to keep the relation to a dimension.
Pier
Tags (2)
