Is there a way to show datum targets spanning multiple views and sheets of a drawing? I'm able to show the annotations on sheet one but the "Show Annotation" field is blank on the sheet two.
What am I doing wrong?
Datums should allow multiple instances in valid orientations. Dimensions only show in one location.
I'm able to show datums without any problem. It's the datum targets that only show up on one page.
Now that would be silly, woundn't it. You might submit this as a support case.
