Team,
Actually I am working on Creo Drawing and i am trying to print respective drawing but unfortunetly some steps i am doing again again like Printer properties Setting
Page orientation landscap, Output Size, ETC. Are there any configuration file for Printer Orientation and Ouput Size (Print Properties). Please Help me to resove this...refer attached image
Dinesh,
Do you use Plotter Configuration Files (.pcf)? You can use these to preset defaults as you describe above so you can choose the appropriate one from the list and then you don't have to go into the printer properties every time you print.
There is some info in the Creo help centre for how to set these up, though feel free to come back here if you have any questions.
David
Dinesh,
just a comment... in Windows you can create printer and set its default settings. This procedure enables you to select Windows printer and print.
And also ... you can create several "instances" of the same printers each one with different default settings.
Martin Hanak
Dinesh,
David
Thank you so much David,
I trying to Set .pcf file but unable to set these file. if you dont mind Can you please suggest any specific step for the same
Kind Regards,
Dinesh
Dinesh,
just a note ... in PCF file you cannot preset options, that belong to Windows Printer Properties dialog box.
Martin Hanak
Martin,
Just i tryied to search these file and found some .PCF file in our PTC Creo-Text- folder. I confused what are these file and what is use of the same??
Can I create any .PCF file for Printer in Creo-Text folder like:
plotter MS_PRINT_MGR
plot_drawing_format YES default
Dinesh,
you can add the following line into existing ms_print_mgr.pcf file.
You will get ms_print_mgr.pcf file with following contents:
plotter ms_print_mgr
button_name MS Printer Manager
button_help Print using Windows Printer Manager.
The purpose of PCF file is to save options selected/set in Creo Print dialog box.
Martin Hanak
Thank You Martin...
Dinesh,
Below is an example of on of my pcf files. In this one, it prints the drawing on A3 paper from a specific printer. Regardless of what size the drawing format is, it re-sizes it when printing, so you can just choose this from the list and click OK, no need to go into the printer properties.
plotter POSTSCRIPT
button_name A3 BLUE
button_help Print A3 size on printer Blue.
plot_segmented NO default
plot_roll_media NO default
plot_label NO default
plot_handshake software default
create_separate_files NO default
plot_with_panzoom NO default
rotate_plotting NO default
allow_file_naming NO default
plot_name NO
interface_quality 3 default
plot_destination printer default
plotter_command windows_print_manager \\server_name\printer_name
pen_table_file table.pnt
plot_sheets current default
paper_size A3
paper_outline NO default
plot_clip NO default
plot_area NO default
Obviously you need to change server_name and printer_name as appropriate for you, for a different paper size, change paper_size A3 to paper_size A2 (for example).
Martin can probably clarify this, but I don't think you actually need to include the lines that end in "default", however that's what is in this particular file.
Thank You David,
You mean to say that I have to Create .pcf file and save it to PTC Creo Text Folder right???
Dinesh,
if you set config.pro optionPRO_PLOT_CONFIG_DIR, then you can save PCF files into the directory mentioned in this option.
Martin Hanak
Yes, as Martin says, you can use config.pro to define the folder location, then you can create as many pcf files as needed.
Thank You all....Issue has been resolved by .PCF and I set printer to generic setting.
Thank You
