Decimal places not displayed correctly when set to limits.
lnick
1-Newbie
Hello all,
All of our dimensions are three place by default, but occasionally we have some two place dimensions. When the tolerance of a two place dimension is set to limits, it shows on the drawing with three places. This only occurs for dimensions that are driven (which are almost always used). If a dimension is created (inserted) in the drawing, it displays as it should (see attached). I have looked in the drawing options and the config file, but didn't see any settings, that jumped out anyway. I have been told this is a bug in the software, but was curious if anyone else has come across this issue. Wildfire 3, M120. Perhaps this was corrected in a later release...
Thanks in advance for any help/input.
0 REPLIES 0
