Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
Decimal places not displayed correctly when set to limits.
Hello all, All of our dimensions are three place by default, but occasionally we have some two place dimensions. When the tolerance of a two place dimension is set to limits, it shows on the drawing with three places. This only occurs for dimensions that are driven (which are almost always used). If a dimension is created (inserted) in the drawing, it displays as it should (see attached). I have looked in the drawing options and the config file, but didn't see any settings, that jumped out anyway. I have been told this is a bug in the software, but was curious if anyone else has come across this issue. Wildfire 3, M120. Perhaps this was corrected in a later release... Thanks in advance for any help/input. This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
