Hi all,
From time to time we are experiencing that the decimals disappear when editing dimensions in sketcher or part modeling.
What happens is that when editing a dimension to, say 14.5 mm, it is rounded off to 14 mm. The decimals disappear.
This is not just a matter of setting the number of decimal places (which are default set to two decimals). The actual dimension is stored without the decimals and when you try to correct it you are no longer able to edit the dimension.
The issue arises in the middle of a session and - so far - requires a restart of Creoto solve. We have seen this on both M30 and M50.
Has anyone else experienced this?
Cheers,
Johann
