I´m struggling with declaring variables for quiet some tiem. Someone showed me some months ago how to declare a variable and give a value to it and what I can remeber it has to do with notebook and layout. Unfortunately I can´t remember anything else and can´t figure it out.
What I intend to do is create a name which a value will be given. And this name I can use it in my part in the relations for example "mass=variable*5" And the "variable" should have been created somewhere and somehow with a given value.
I know that when I go to my part I need to go to "declare variable" and then in Notebook select the layout... But how can I create this layout?
Thanks a lott!!
Best regards,
Edna
Edna,
I assume you want to use the same parameter in multiple models controlling it via the notebook.
As a convenience, it's nice to create a table in the notebook that lists all the parameter names and their values. It makes it easy to "edit value" vs. entering the parameter UI to change the values.
Good luck with the notebook.
Daniel Nordin
BAE Systems
www.baesystems.com
Edna,
Daniel Nordin
BAE Systems
www.baesystems.com
Thank you so much
Best regards!
Edna
