Hello
We have placed a hole into part file. It is threaded hole. Once I check dimension related to hole diameter, it is showing as Dia.14. Is there a way to change default representation for hole diameter dimension in case of threaded hole?
What we need is to have M15x1.5 (M Diameter value X Pitch Value).
Thanks and Regards
Ketan
no such config.pro option is available. You have to use mapkey or trail file.
If you use a standard threaded hole from the drop-down list in Creo, M16x1.5 for example, then on the drawing sheet you can show the dimension as an annotation (Annotate > Show Model Annotations).
Modify the standard text to provide your required specification.
Note: M15x1.5 is not an option in this case because the Creo drop-down menu for standard threaded holes only contains ISO preferred sizes.
Hi, You can create new hole tables for non-std threads if they are you're company preferred versions. It's a fair bit of work to create them but might be of benefit. Years ago I had to do just that for some special spec plugs that were being used in a complex hydraulic block. I think that you also need to make sure the file is in a suitable location to be called in. If needed I could try to remember how I did this.
If you create a normal dimension then by default the dimension is shown with a diameter symbol before the value.
Select the dimension, right click and open the Properties dialog. Select the Display tab and change the dimension's prefix to M. Add a suffix too if required to get M15x1.5.
I am looking forward to avoid manual work. Is there any specific option or setting which do place hole diameter dimension in part as M15x1.5?
