Diameter with broken leader
Highlighted
Newbie
In a general or partial/detailed view, how do you create a broken diameter
leader? Not the double arrow one but the sort of side shifted kind. Let's
see if this drawing helps..
[image: image.png]
Will someone help the poor innocent souls of the CAD community. please!!
thanks
Alfonso
Highlighted
RE: Diameter with broken leader
You are asking for a foreshortened radius dimension. I did a quick check in the PTC knowledge base and noticed it is a "what's new" item for Mildfire 5. We use 4 here, so if you have 5 you may be in luck.Otherwise the alternate technique is given in TAN 114578. I noticed foreshortened radii were asked for back in Pro/E 2001 and they finally have it available in MF5. I know foreshortened radii were available in Solidworks 2008.
