Annotation ( CoCreate vs. 17 😞 Does anybody know why the "Modify Dimension Break Line" command reverts back to the original "non-modified" state as a result to View Updating? This is very annoying, because of all the extra work it creates. What's more, no drawing should be put into an unreliable state after having confidence that a particular version is approved!
Thanks.
-- Stephan
if you have a valid and active Maintenace contract can you please take/report this to the Technical Support group of PTC ? then they would be able to verify this and to report this to R&D if it requires a change in the implementation.
Horst
