Dimension in multiple drawing layers
Drs95
Hi all, currently I have a drawing with many dimensions and I have a rule based layer that select all those dimensions.
Then I create another layer(Layer 2) and I need this layer to have some of the previous dimensions selected on the rule based layer, the problem is when I import the layer in the PDF, the dimensions that belongs to rule based layer and 2nd layer only show in the rule based layer (the common dimmensions) and I need those dimmension to be available on the Layer 1 and Layer 2
I've been looking for 1 week on the PTC Forum and haven't been able to found anything, also have been looking for documentation and got some power points presentation but this has not helped me with my problem
Anyway, any answer will be kindly read by me, have a nice day.
DR
7 REPLIES 7
MartinHanak
24-Ruby II
(To:Drs95)
I suggest you to create example data and upload them to show the problem.
Martin Hanák
Drs95
(To:MartinHanak)
Hello Martin, thanks for your answer here I show my problem in 2 images in a word document. I hope it is clear.
MartinHanak
24-Ruby II
(To:Drs95)
I can't see any Word document.
Note: It would be better to upload Creo files.
Martin Hanák
Drs95
(To:MartinHanak)
Hi Martin, I can't share the creo document because is confidencial also, sorry for not attaching the word. Here it is
MartinHanak
24-Ruby II
(To:Drs95)
1.] I can reproduce the problem
2.] I suggest you to report the problem to PTC Support
Martin Hanák
Drs95
(To:MartinHanak)
Hi Martin, so this is a problem it's not that I'm managing poorly the layers?
MartinHanak
24-Ruby II
(To:Drs95)
I think the root of the problem is imperfect Creo functionality. I guess that there is no documentation explaining how Creo manages layers during the export of drawing into PDF format.
Martin Hanák
