Dimension settings defaults
SOLVED
Visitor
When I place a dimension it is 3 places, I can go into properties and change it to 2 places, but I have to do this to each and every dimension.
Is there an doption to change the default from 3 places to 2 places so that when I create a ne one it comes in as 2?
In addidion, can I make it so that my dimensions come in as fractions?
I am hoping it is an option in the .dtl (drawing properties) or in the config.pro (configuration editor) file.
1 ACCEPTED SOLUTION
Re: Dimension settings defaults
Also try the config.pro option
create_fraction_dim YES
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
5 REPLIES 5
default_dec_places in config.pro can control the number of decimal places for a dimension.
deafult_dec_places 2
DTL file setting dim_fraction_format will control how dimensions use fractions.
Highlighted
I found the decimal place option in the config.pro file (Thanks, it was an option that didn't show up until I changed the value).
But the fraction setting doesn't seem to do anything in the .dtl file.
I have picked the std and the aisc options (as well as default) and nothing seems to change with either option.
Steve Williams
This did it. Thanks!
Don't forget to mark Stephen's answer as correct.
