Dimensions
SOLVED
Visitor
Dimensions
We are trying to figure out how a user was able to create a draft dimension and rename it to match a driven dimension.
Re: Dimensions
Does your drawing already have an existing CREATED dim called DIM8?
Stephen Williams
Pro/E Version 15/16 (Circa 1995/1996)
Re: Dimensions
You can rename created dimensions. They simply renamed it so it matched the driving dimension.
Stephen Williams
Re: Dimensions
I tried that but it won't allow it.
Tags (1)
Re: Dimensions
Stephen Williams
Re: Dimensions
Nice catch.  User had already renamed a dim but did not change it to @S.  Thought the user had some new trick I had not heard of.  Thanks for your help!
