Display Draft Angle on Section View
Visitor
I have a part with a hole through the center.  I applied draft to the part and split the draft at a hinge part-way through the surface.  Different draft is applied to either side of the draft hinge.  When detailing on a drawing, I have a cross section through the "front" plane within the part.  When I use the Annotation > Show Model Annotations to display the dimensions of the draft feature, the dimensions are shown at the center of my view, seemingly fixed to an orthogonal plane to my section.  If I make a different cross section through this "side" plane and move the dimensions to this view, they display differently.  See attached file for screenshots.
Has anyone also experienced this behavior?  Any idea why the dimension displays differently on the two different sections?
I'm running Creo 5.0.5.0
-John
