I have never encountered this situation before. I am unable to display the values for Saved Analysis Features in a drawing. In fact I cannot show them using "Show expression" in the relationship editor? The part is a sheetmetal part. First I figured I could save a saved analysis and display the results of that analysis on the drawing. That did not work so I saved the analysis as an analysis feature (shown below) and deleted the saved analysis. I simply want to display the length, width and height of a sheetmetal part representing a carton. At first I thought since the active model was the flat pattern that might have something to do with displaying the dimension. So, I made the Generic active. Does not matter what I do, I cannot get the value of the feature(s) to display. The :12 is the session ID of the flat pattern.
Some data on the "Length" feature:
Your parameter is named "DISTANCE", so you need to have "&distance:fid_length".
Thank you. I missed a step. I like to keep both names the same for simplicity sake.
