Can anyone let me know what all things are covered under draft entities in creo drawing file?
Regards
Ketan
Ketan,
Entities in drawing which can create using option in sketch tab in drawing e.g. line, Arcs, spline, circle etc. are draft entities.
Entities in drawing from an IGES, DXF, or SET file are considered to be draft entities.
Converting a view in drawing to draft group will also generate draft entities.
Hi Mahesh,
Thanks a lot for this info...
Is it OK to call the entities present into drawing view as draft entity if view has not been converted to a draft group??
How to identify details of entities present in a view if view is not converted to a draft group??
when you select a draft entity and hover over it, a box will appear to identify it (IDn(DRAFT ENTITY) These are created by hand
when you hover over a view, the box appears with the information (View:new_view_1) These were generated by model geometry.
Ketan,
Does the reply from Ron answer your followup question? You can use search tool as well to find draft entities.
HI Mahesh,
Answer is helpful. I would like to understand whether it is possible to identify details from view for all draft entities without converting view into detail draft group?
Nope, without converting view, entities in view will be solid entities not the draft entities.
