Drag and Drop to Resize Table?
eSheldon
Is there a way to drag and drop to resize a table (BOM), just like every other program?
Using "Height and Width" to itterate and preview the size of a table seems to be time consuming.
Using Pro/E Wildfire 5.0
I guess your talking of BOM in the drawing, if so go to table ribbon and select the table by clicking left top corner, right click for pop up menu options. You will get height and widht property to change. Also you can able to drag and drop by clicking left corner. Indivudal rows can be selcected and properties can be changed.
Right, but that's exactly what I'm trying to avoid.
A properties dialog always takes a lot more time. I'm trying to find a way to be more efficient. Right clicking the table or a column and using height and width adjustment requires iterating. I want to drag the resize certain columns faster to adjust for longer descriptions, materials, etc.
