Drawing Template Repeat Region
SOLVED
Re: Drawing Template Repeat Region
If DRAWING_TABLE is a parameter defined in a regular part, then take these steps:
asm...
mbr...
User Defined
DRAWING_TABLE
It will show as "&asm.mbr.DRAWING_TABLE"
But if you have added Relations to a Repeat Region, and DRAWING_TABLE is defined in those relations, then take these steps:
rpt...
rel...
User Defined
DRAWING_TABLE
It will show as "&rpt.rel.DRAWING_TABLE"
For your info, here are the Repeat Region Relations I made in a test part. The test part has a paramet name "DRAWING_TABLE" with a value of "SPEC_G_1245". The Repeat Region Relations create a new parameter called ZZ which I have added to the BOM. Notice the way that you'll need to reference the DRAWING_TABLE parameter (you'll have to replace all dots "." with underscores "_")
XXX = asm_mbr_drawing_table
Y = "SPEC_"
XX =extract(XXX,string_length(y)+1,string_length(xxx)-string_length(y))
Z = search(XX,"_")
if Z == 0
/* The string does not contain an underscore
ZZ = XX
else
/* The string has an underscore
ZZ = extract(XX,1,Z-1)+"-"+extract(XX,Z+1,string_length(XX)-Z)
endif
Highlighted
You could also use the exists function to check if a part has the "DRAWING_TABLE" parameter:
if exists("asm_mbr_drawing_table")
Y = "SPEC_"
Z = search(XX,"_")
if Z == 0
ZZ = XX
else
endif
else
ZZ = "Oops"
endif
Highlighted
@bwudtke, did you succeed in showing "DRAWING_TABLE" in your repeat region?
Highlighted
@HamsterNL   Thank you so much for the time on this.  This helps alot, I have gotten the table to work, but still am having problems with the filter to remove anything that does NOT have the "DRAWING_TABLE" parameter.   I have tried adding a filter, &asm.mbr.param == DRAWING_TABLE, but it removes everything from the table.  Thoughts?
Highlighted
Try
&asm.mbr.param.name == DRAWING_TABLE
Highlighted
That did not seem to work. 😕  I have attached my drawing file if this helps at all.
Highlighted
Can you show an actual generic part number and describe what you are doing?
Highlighted
All I am trying to do is filter a "simple" repeat region to only show parts that have the parameter "DRAWING_TABLE."  The file above has a sheet metal part BOM with two bulk items that contain the parameter "DRAWING_TABLE" and the sheetmetal file part in the BOM does not include the parameter.  I just have to get the correct table filter to only show parts that have "DRAWING_TABLE" included and am having a hard time.
Filter:
or
doesn't work
Highlighted
@bwudtke,
I have taken a quick look at your example.
To make it work, I had to edit the Repeat Region Relations, and remove the top half where a "LOST SYMBOL" was being used.
So the Relations are now:
if exists ("asm_mbr_ptc_material_PTC_MATERIAL_NAME") /*if item is a material
if search (asm_mbr_ptc_material_ptc_material_name,"SI") == 1 /* global material?
KPS = asm_mbr_ptc_material_kpsmat
SDMO = asm_mbr_ptc_material_ptc_material_description
thick = asm_mbr_ptc_material_thickness
mm = 'mm '
endif
endif
/* START - part name
IF search (asm_mbr_name,"_") == 0 /*Search for an underscore in the part name
partnum = asm_mbr_name
ELSE
partnum = extract(asm_mbr_name,1, search (asm_mbr_name,"_") - 1) /* If name has an underscore, then truncate the Part No.
endif
/* END - part name
Then I modified the Filter to:
The table then showed only two entries B (the two bulk items)
Highlighted
@HamsterNL   This is what did it!!  Thank you so much!
