Is it possible to change the size of a drawing views boundaries? The drawing views are so large that they over lap each other.
I know why the drawing view is sized the way it is, the geometry is far away from the default Csys.
Steve
Make your view a "partial view" under the "visible area" in the view properties dialog box and sketch the spline around the view. It will reduce the size of the view boundary to fit more appropriately.
