John,
Did you ever find the cause of this? I am experiencing the same problem now.
Creo 3.0
That's very strange. I would recommend contacting support and getting an SPR filed, so I can have the job of hunting down the cause.
It's not unusual if you have added features or datums to your model. Are you saying it's shifting without changes to the model?
I was working from the statement that the shifting was caused by a difference in config.pro settings, which sounds pretty seriously wrong. If Mike is just seeing shifted views, I agree the first thing to check is whether the view outline changed as a result of the model getting bigger.
I completely agree.
We are getting the changes from User to User, no changes to the model.
User1 - saves a drawing
User2 - checks drawing, sees views shifted slightly off the border to the LEFT. Moves views back to center.
User1 - Reopens drawing and now sees views shifted slightly off border to the RIGHT!
Creo 3.0 M040
Mike
Good to hear. Well, bad to hear, but at least it's clear. Please do get an SPR filed for it, and I'll take a look.
Make sure that both users are referencing the same models at the same revision and same iteration. I've seen user play table-tennis like this until one of them finally updates all the models they have to match the other.
This presumes the origins of the views haven't been fixed to invariant references, like an initial CSYS.
