I am trying to change color here. But not changing 😞
The color is the same as that given created dimensions that have lost references.
If references are missing (there should have been a message that said references are missing): Select one and then right click - edit attachment and pick suitable replacements for the missing references.
Yes David, You are right. I agrre with you.
But if any case is there any chance to change that color or not?
sometimes its usefull to me.
AraviK
herer u can change dimension colour
by the by which version of pro-e are you using this option is in creo 1.0 and 2.0
I'm not sure where to change the color of unattached dimensions. The color is there as a warning that the dimensions no longer represent any geometry.
If you reattach the dimensions, they will use the dimension color.
Thanks sanosh. i am working on WF5. I was aware of this color change, My question was different.
Yes David,
If we do edit attachement prob will solve, apart from that i was trying to edit that color. Because so many dimensions were here to do edit attachment but that attachments are at correct place .
I hope no solution for my question.
AraviK
In the System Appearance Menu -> Global Colors -> Graphics -> Change the "Manufacturing Volume" color.
Yes, I agree, cuz that makes sense?!?
Upcoming October 2019
Regional User Groups
