... need help with creo config setting up:
i use dual dimensioning on drawings and need help with setting up maximum number of digits (to 1 or 2 more than primary) at dual secondary dimensions as below
there are 13digits behind zero until i tick the "rounded dimension value" at each dimension separately
Is there some possibility to set up that all secondary dimensions are rouned automaticaly?
a printscreen of confin.pro:
