Hi everyone,
In WF5.0, when you create a new page, it drops it at the end, which is OK. What's not is if you want to add a sheet in the middle of an existing drawing.
For example, if I have a 20 sheets drawing and I want to add a new one between sheets 10 and 11, I create a new sheet that then becomes sheet 21. I know I can move it where I want, but it still is called sheet 21 in the tabs at the bottom. Is there an automated way to rename the sheets in the bottom tabs so that they get in order?
Fred
