Drawing template and DTL file relationship
SOLVED
Aquamarine
Currently we have a dtl file stored on a shared drive and the site config.pro points to this dtl file. I would like to move the dtl file onto windchill but Im not sure if I need to. Our drawing templates are stored on Windchill and it seems like they already have had a dtl file applied and when creating a new drawing from template the dtl file specified in the config.pro is ignored, is this correct, can I just update the templates with the new dtl file and them upload the templates into Windchill?
Tags (2)
Re: Drawing template and DTL file relationship
Yes, .dtl files are NOT used when you start a new drawing with a template.
If you updated the .dtl in the template, then your new drawings will get the new settings.
You may still need an updated .dtl file available if you copy old drawings or have old drawings that you want to update to the new .dtl settings.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Steve Williams
Thanks, I will leave the latest dtl on Windchill alongside the templates for legacy drawing updates and update all the templates with it.
