Drawing views are moving by their own will...
jhengel-2
Hello All,
I having some issues with a large assembly drawing. Every time I open the drawing I notice that the views have moved. The views are in shaded mode. I was wondering if anyone out there has experienced this or may now of a solution.
We're using Creo Parametric 2.0 Date code M120.
Thanks!
John
Did you change any components in the assembly?
Yes, I replaced components within the assembly.
John, see this discussion on the 'Other Exploder'...
http://portal.ptcuser.org/p/fo/st/thread=55957
I think it may shed some light and also propose a solution.
John
