Dual Dimension - Position
Guest
This is the common question going around the office; we use dual dimensioning on all our drawings, we have everything setup so the dual dimensions display. However, what happens is the second dimension is usually placed below the line on the dimension and then we have to select, properties and select to right rather than below.
Is there anyway to make sure these automatically come in the position 'To Right' rather than below? I'm pretty sure there isn't but I'm hoping this is just something I can't find.
Tags (2)
Re: Dual Dimension - Position
I don't believe there is an option for that.
There is a enhancement request (product idea) open for voting
https://community.ptc.com/t5/Creo-Ideas/Make-dual-dimension-position-value-quot-to-right-quot-or-quo...
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
is there no config option to set this up front yet.  I know this post is old and can't believe there isn't a config so annoyed!
