Dual Dimensioning - how do I remove run-on decimal places?
SOLVED
Newbie
I believe this is a bug, but because the company for which I work does not have a maintenance plan, I am unable to let PTC know about the bug.
I am using Creo 2.0, and in my drawing, I am showing the driving dimensions which are in MM. I have Dual Dimensioning turned on and am displaying the secondary dimensions (inches) first, and then the primary dimensions (mm) as the dual dimension.
It's hit or miss as to whether the dimensions show up properly, but when the secondary dimension displays incorrectly (with 12 decimal places versus the specified 3), it won't accept any modification in the Dimension Properties dialogue box.
I've gone through all the config options and verified:
Again, I've tried editing the Dimension Properties, but to no avail:
Here's a snapshot of what the dims look like:
Does anyone have any idea how to fix this? If not, is there any way you can notify PTC of this thread so they can be aware of this bug?
Thanks in advance!!!
Re: Dual Dimensioning - how do I remove run-on decimal places?
click the Rounded Dimension Value checkbox.
My pics were not included...
Thank you!!
You are welcome, Beth.
