Dxf Version in Jlink
ddhini
I need to Export the drawing file to dxf format usinh Jlink .
Creo provides an option to export an drawing file to dxf is as follows,
 DXFExportInstructions dxfexportInstructions = pfcModel.DXFExportInstructions_Create();
draw.Export(draw.GetFullName(), dxfexportInstructions);
It works fine ,It will convert the drawing to DXF in a lowest version 2007 ,but i want to change the dxf Settings using Jlink.please guide me to solve this.
1 ACCEPTED SOLUTION
RandyJones
(To:ddhini)
@ddhini wrote:
Thanks, We cant set the DXF version through Jlink. Instead we can set through the Config file ,
Jlink allows you to get and set config options:
String originalValue = session.GetConfigOption("dxf_export_format");//original version
session.SetConfigOption("dxf_export_format", "2013");//desired value
//do something...
session.SetConfigOption("dxf_export_format", originalValue);//reset to original value
3 REPLIES 3
RandyJones
(To:ddhini)
Take a look at the config.pro option dxf_export_format. I don't know for sure if this controls the version when exported from jlink however I suspect it does. This option can be set from jlink if needed.
ddhini
(To:RandyJones)
RandyJones
(To:ddhini)
//do something...
