Hi, I just use the Creo. my problem: I cannot edit text title block in type "drawing"
History:
- I has copy template from AutoCAD and edit in Creo 1 type "format", status success.
- I create type" drawing" and use specify template "empty with format" and choose the template that I has edit in type"Format"
- Template is visible but cannot edit or like freeze
what is problem:
1. My PC'hardisk is slow?
2. How to edit text ?
Slow PC can only be solved with an upgraded.
Your format file does not have variable. It is frozen because the text is fixed in the lower level file... the format file.
Format files with variable text are special and cannot be imported. They are made from tables. The tables have variables entered into them. This is the only way to make them editable when used in drawings.
Only tables inserted to formats can be edited in the further created drawing. Notes that you insert into format can't be edited in the drawing using the format.
Not sure about AutoCAD blocks.
