Emn and emp files
kwsauter
Emn and emp files
Does anybody know if there is a way to import the reference designator
or actual part number when importing emn files? All I have ever got was
whatever size designator the layout guys give the component, but nothing
as to value, part number, or reference designator. I understand that's
enough to get a good representation of the board, but I sometimes need
to know what the actual part number or value is, and I don't know of
anywhere in an emn file that that information shows up.
Has anyone been able to import this information?
Ken Sauter
DRS Reconnaissance Surveillance and Target Acquisition
Infrared Technologies Division
PO Box 740188
Dallas, TX 75374
469-221-5430
NOTICE: This e-mail transmission (and/or the attachments accompanying
it) may contain confidential or proprietary information belonging to DRS
Technologies or the sender. The information is only for the use of the
intended recipient. If you are not the intended recipient you are hereby
notified that any disclosure, copying, distribution or the taking of any
action in reliance on the contents of this information is strictly
prohibited. Any unauthorized interception of this transmission is
illegal under the law. If you have received this transmission in error,
please promptly notify the sender by reply e-mail, and then destroy all
copies of the transmission.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior written approval from the U.S. Department of State."
Hi Ken,
The information from the emn file is imported at the PCB Board .asm level.
This information is not available at the part level.
To view the reference designator information at the board assembly level,
choose Settings, Tree Columns, and add the reference designator to your
model tree. I believe the ecad_name and the ecad_alt_name can also be
added to the tree columns.
To view the "value" and "part number" in Pro/E, this information needs to
be the emn file upon export from your ECAD Tool. Prior to export to an
emn file, most companies set up the ecad_name to be the footprint
(geometry) name. Some companies set up the ecad_alt_name to be the part
number. See page 5 of the powerpoint at the following link:
