I am exporting a single sheet drawing to PDF (File > Save As > Export) and for some reason, it creates a 2nd page of the template file that is blank (just has the border & title block). I looked through the PDF settings and I don't see anything related to this. I actually didn't realize it was doing this until a customer pointed it out. Any insight?
I guess that our problem is related to your data. If you can, upload them for testing purposes. In other case you have to do testing in Creo to find the root of your problem ... for example create empty A4 drawing and export it into PDF.
You try printing it and use a PDF writer. It might solve your problem.
