Hi Toolkiters,
I faced a problem with the geometry export.
What I need is to export just a couple of preselected faces of a part. Tried to use layers, but this didn't help,
entire part was exported.
Do you have any suggestions how to do this?
Thank you much,
Vlad.
I suspect there's no way to export a quilt only.
So, as a workaround, is it possible to copy this quilt to new part and then export it?
Thanks much,
Vlad.
Let it be IGES, I don't care.
I don't think filtering by type will help, since I may have other surfaces, quilts etc., but wanna export only one.
Vlad.
David,
Would you explain this?
Thank you,
Vlad.
In Reply to David Bigelow:
Then copy reference to a new part and export that...
On May 30, 2009, at 10:53 AM, "Vladimir Ivanov" <triz_mail@ukr.net>
> Regards,
> Vlad.
David,
Let's consider I already have Copy feature.
I wonder how I can copy it to another part.
Vlad.
Hi all,
There is an example 'Export a Model File to IGES Format 'in Pro/Toolkit user guide. I would try to set ProOutputBrepRepresentationAlloc()to quilts and place solid geometry on blanked layerand ProOutputInclusionFlagsSet() set blanked to false.
If previous would not work then the following approach could be tried:
Build interchange data ProPartToProIntfData(), start a new part with ProSolidCreate(), and useProImportfeatCreate(). There was an example in the manual.I don't remember if ProPartToProIntfData() would allow to control which entity(s) to export. Ifnot thenProIntfDataQuiltAppend could be used tobuild ProIntfData by hand.I think there was an example of this in the manual as well.
If nothing worked one could use a brutal appoach by calling a mapkey or trail file from Pro/Toolkit via ProMacroExecute().
HIH.
Feliks.
