I have a particular inspection system that requires a .csv file containing a list of points to define a nominal curve.
I have taken my 3D model and generated both a pattern of datum points along the curve. I've chosen 1000 points but I'm a bit flexible on that quantity.
I'm using Creo 2.0 Parametric and have Excel at my disposal to groom the data and export to CSV if necessary. Of course I would prefer if Excel is not required. I found a couple of old things on the web but the links are dead.
Please advise of a good clean way to make this conversion to CSV. I've forgotten any useful programming that I used to practice to make my own conversion script. Thanks,
David
