Extracting Dimension from Creo model
Re: Extracting Dimension from Creo model
I hope the below code will help you up.
Dim model As IpfcModel
Dim solid As IpfcSolid
Dim holes As IpfcFeatures
Dim hole As IpfcFeature
Dim dimensions As IpfcModelItems
Dim dimension As IpfcDimension
model = session.CurrentModel
Solid = CType(model, IpfcSolid)
holes = solid.ListFeaturesByType(True, EpfcFeatureType.EpfcFEATTYPE_HOLE)      " This will give you the whole list of holes present in your model"
For i = 0 To holes.Count -1
hole = holes.Item(i)     "Now it will go through each holes. If you want to check any perticular hole. You can do that by using the Feat-Id of the hole"
dimensions = hole.ListSubItems(EpfcModelItemType.EpfcITEM_DIMENSION)
For j= o to dimensions.Count -1
dimension = dimensions.Item(j)
Next
Next
