Failure to retrieve (err = -1) for Save As Drawings Publishing
ptc-1174045
Error from worker log:
$ERROR$ Failure to retrieve D:/ptc/CadWkr/w1i1j1/part_for_e009_2_saveas.drw name part_for_e009_2_saveas (err = -1)
All other data poublish well except the Save As Drawing. Any inputs & solutions will be appreciated.
When we have the Property set as below, everything works fine but we have a customization to do an auto publishing that will not work...
publish.cadconvert.PROE=com.ptc.wvs.server.publish.CadConvertPROE,useworkerdownload\=$(wt.home)$(wvs.dir.sep)auth.properties,usewcfileserverlookup\=true
However if we set the property as below hard coding the absolute path everything works except the publishing of Save As Drawings
publish.cadconvert.PROE=com.ptc.wvs.server.publish.CadConvertPROE,useworkerdownload\=D:/ptc/Windchill_9.1/Windchill/auth.properties,usewcfileserverlookup\=true
0 REPLIES 0
