Family tables on drawings
kwsauter
It has been a while since I've put family tables on drawings, and I
guess I just forgot how to do it. I know I have to put
&fam.inst.param.value in every cell to have anything show up, and that
gets all of the family table values of all variables all showing up. So
far, so good. Then I have to specify filters to get individual values
to show up in a column. I can get an individual dimension showing up
properly so it shows all the different values of that dimension. But I
can't get the family instance name to show up. What is the filter to
make the family instance name show up?
Ken Sauter
DRS Reconnaissance Surveillance and Target Acquisition
Infrared Technologies Division
PO Box 740188
Dallas, TX 75374
469-221-5430
NOTICE: This e-mail transmission (and/or the attachments accompanying
it) may contain confidential or proprietary information belonging to DRS
Technologies or the sender. The information is only for the use of the
intended recipient. If you are not the intended recipient you are hereby
notified that any disclosure, copying, distribution or the taking of any
action in reliance on the contents of this information is strictly
prohibited. Any unauthorized interception of this transmission is
illegal under the law. If you have received this transmission in error,
please promptly notify the sender by reply e-mail, and then destroy all
copies of the transmission.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior written approval from the U.S. Department of State."
jellis
11-Garnet
(To:kwsauter)
Hello Ken.
Do you have &fam.inst.name as the report parameter for the instance column?
Here's a PTC link: Suggested Tech for creating a table of a family table part.....
http://www.ptc.com/cs/cs_26/howto/dwt_no2d/dwt_no2d.htm
mjenkins
(To:kwsauter)
You can just insert the included table:
In Reply to Kenneth Sauter:
Ken Sauter
PO Box 740188
Dallas, TX 75374
469-221-5430
Michael R. Jenkins P.E.
Design Engineer
Direct: 816-801-2332
Fax: 816-891-9432
Commercial Vehicle Systems
Haldex Brake Products Corporation
10930 North Pomona Avenue
Kansas City, MO 64153-1215
