I'm trying to create views similar to the ones shown in this pdf file, in particular view "A-A". I thought there used to be an "unbend" drawing view type but I can't seem to find anything to flatten the views. I'm sure there is a way to make these views I'm just not finding it.
Sam
Wildfire 2.0
Datecode M180
The key to using an "unfolded" xsection is to first create the xsection as an Offset cross section.
The next prerequisite to it not being greyed out is that every part of the sketch of the Offset cross section must be a straight line. Then you will be able to choose this type and show it. I think it also must be a new view. You cannot change an existing view to an unfolded xsection for some reason.
In Reply to Bjarne Frandsen:
Sam,
This is called an unfolded section view in ProE. I have never succeded in
making one myself as this type seems to always be greyed out when defining
the section view on the drawing. I must be doing something wrong I guess.
If you find out please post a summary.
Regards
Bjarne
"Samuel Snively" <->
03-02-2009 19:19
Please respond to
To
cc
Subject
[proecad] - Flat Drawing View
Sam
Wildfire 2.0
Datecode M180
