Flexible Component Animation with MDO
Newbie
I have one component set to flexible (with one variable dimension) in an assembly. The component needs to change it's geometry (modifying the variable dimension) throughout an MDO analysis/animation--preferably this variable value would be defined by a relation that could reference a parameter or saved feature. I am hoping that throughout every frame of the animation these values would update and the one component would change to fit. Obviously I need this component to deform (in a controlled manner) based on what other components in the assembly are doing. Does anyone know if this is possible with Wildfire 5.0-Creo2.0?
Thanks in advance.
Re: Flexible Component Animation with MDO
take the picture at every variable steps, then make a combined gif file.
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
